Raspberry Pi installieren: Raspberry Pi OS
Re: Raspberry Pi installieren: Raspberry Pi OS
Kleines Update (ohne Änderung der Anleitung).
Download wie immer hier: Externer Link Download
Änderungen neues Image (hier 64Bit Desktop Version):
raspberrypi.org hat geschrieben:2022-09-22:
* NodeRED removed from Recommended Software and full image - should only be installed via apt
* Improved speed of startup of lxpanel network controller plugins
* Improved detection of Bluetooth HID devices in first-boot wizard
* Bug fix - splash screen version number and date incorrect
* Bug fix - text entry in searchable main menu ignored while caps or num lock active
* Bug fix - keyboard shortcuts to open Wi-fi and Bluetooth plugin menus not working in 64-bit builds
* Bug fix - typo in Bluetooth device menu
* Bug fix - crash when cycling windows in mutter
* Bug fix - spurious text output in raspi-config network configuration selection
* Bug fix - firstboot script skipped further steps if rootfs resize failed
* Bug fix - firstboot script inadvertently wrote /test.log
* Bug fix - typo in raspi-config resulted in empty file /2 being created
* Raspberry Pi firmware 48cd70fe84432c5d050637b61e4b7b9c831c98bf
* Linux kernel 5.15.61
Vollständige Release Notes: Externer Link Link
Weiteres Update (ohne Änderung der Anleitung).
raspberrypi.org hat geschrieben:2023-02-21:
* glamor now disabled on all platforms other than Raspberry Pi 4 with legacy video driver
* msdri3 video driver support added
* KiCad added to Recommended Software
* Support for new touchscreen driver added to Screen Resolution tool; minor UI tweaks
* GTK message dialogs shown with right-justified buttons
* Bug fix - updater plugin now does not clear icon when an update has failed
* Bug fix - keyboard highlight now shown on GTK switch control
* Some Korean and Brazilian translations added
* Fix rpi-imager hidden ssid configuration
* Install kms++-utils
* Raspberry Pi firmware 78852e166b4cf3ebb31d051e996d54792f0994b0
* Linux kernel 5.15.84
Anleitung und Bilder an neues Image angepasst.
raspberrypi.org hat geschrieben:2023-05-03:
* 64-bit Mathematica added to rp-prefapps
* Bug fix - occasional segfault in CPU temperature plugin
* Bug fix - X server crash when changing screen orientation
* Bug fix - X server DPMS not working
* Mathematica updated to 13.2.1
* Matlab updated to 23.1.0
* Chromium updated to 113.0.5672.59
* Raspberry Pi Imager updated to 1.7.4
* RealVNC server updated to 7.0.1.49073
* RealVNC viewer updated to 7.0.1.48981
* Updated VLC HW acceleration patch
* libcamera
- Add generalised statistics handling.
- Fix overflow that would cause incorrect calculations in the AGC algorithm.
- Improve IMX296 sensor tuning.
* libcamera-apps
- Improve handling of audio resampling and encoding using libav
- Improve performance of QT preview window rendering
- Add support for 16-bit Bayer in the DNG writer
- Fix for encoder lockup when framerate is set to 0
- Improved thumbnail rendering
* picamera2
- MJPEG server example that uses the hardware MJPEG encoder.
- Example showing preview from two cameras in a single Qt app.
- H264 encoder accepts frame time interval for SPS headers.
- H264 encoder should advertise correct profile/level.
- H264 encoder supports constant quality parameter.
- Exif DateTime and DateTimeOriginal tags are now added.
- Various bug fixes (check Picamera2 release notes for more details).
* Some translations added
* Raspberry Pi firmware 055e044d5359ded1aacc5a17a8e35365373d0b8b
* Linux kernel 6.1.21
Anleitung und Bilder an neues Image angepasst (Bookworm 64Bit).
raspberrypi.org hat geschrieben:2023-10-10:
* Based on Debian bookworm release
* Support for Raspberry Pi 5
* Desktop now runs on the Wayfire Wayland compositing window manager on Raspberry Pi 4 and 5 platforms; on X11 using the openbox window manager on older platforms
* lxpanel replaced with new wf-panel-pi application when running Wayland; existing lxpanel plugins migrated; gpu performance and power plugins added
* pcmanfm modified to use Wayland backend when running on Wayland
* PipeWire used instead of PulseAudio as audio control subsystem; various changes made to volume control plugin to support this
* NetworkManager used instead of dhcpcd as networking interface; various changes made to networking plugin to support this
* Firefox browser added as alternative to Chromium; selection of default browser added to Raspberry Pi Configuration tool
* WayVNC VNC server used instead of RealVNC when running on Wayland
* All customisation and configuration applications modified to customise Wayfire environment as appropriate
* grim used as screenshot tool instead of scrot when running on Wayland
* eom image viewer used instead of gpicview
* evince document viewer used instead of qpdfview
* Chromium web browser updated to version 116
* VLC media player updated to version 3.0.18
* Magnifier program not available when running Wayland; Wayfire includes screen zoom capabilities
* CustomPC and Wireframe removed from Bookshelf
* Numerous small changes and bug fixes
* Switched from raspberrypi-kernel to Debian-based kernel packaging (linux-image-rpi-*)
* Switched from raspberrypi-bootloader to Debian based firmware packaging (raspi-firmware)
* /boot mount point moved to /boot/firmware
raspberrypi.org hat geschrieben:2023-12-05:
* Serial port switching in rc_gui and raspi-config modified to support Raspberry Pi 5
* Touch screens now identified with unique per-device strings to enable correct association with display devices
* Compatibility with RP1 displays added
* Theme files monitored by pixdecor plugin to load changes on the fly
* Main menu shortcut to The Magpi website restored
* GTK+2 theme harmonised with GTK+3 theme to enable more uniform theming of Qt applications
* Battery monitor plugin enabled
* Taskbar Preferences menu item added to panel right-click menu
* Better reloading of on-the-fly theme changes
* Various improvements to Wayfire rendering
* Dark GTK theme added
* Bug fix - suppressed warning notifications when removing USB devices without mounted filesystems
* Bug fix - volume keyboard shortcuts locked up on some devices
* Bug fix - correctly handling multiple USB audio devices with same name
* Bug fix - some translations not loading in panel plugins
* Bug fix - window titlebars disappearing when tiled
* Bug fix - local installer service failing to install local deb files
* Bug fix - wizard not correctly setting locale when explicit UTF-8 character set required
* Bug fix - system updates could fail if an update required the removal of an installed package
* Bug fix - prevent file manager windows opening larger than screen size
* Bug fix - GPU plugin displaying load percentage as -1
* Bug fix - various window manager crashes associated with shadows on certain window types
* Bug fix - allow VNC to be enabled if either RealVNC or WayVNC are installed
* WayVNC - improved support for encrypted connections
* Mathematica now works on Raspberry Pi 5 and 64-bit
* Scratch 3 now works on Raspberry Pi 5 and 64-bit
* Thonny updated to version 4.1.4
* Chromium updated to 119.0.6045.171
* Firefox updated to 119.0
* gpiod binary tools included in lite images
* python3-venv included in lite images
* Japanese translations updated
* German translation added to Appearance Settings
* Raspberry Pi firmware 12af703dd07d7721c1f2f58c6f71d9fe66270838
* Linux kernel 6.1.63
Diesmal gab es zwei kurz hintereinander erschienene Images vom 12.03.2024 und 15.03.2014.
Das damalige Image vom 11.12.2023 hatte ich ausgelassen (minimaler Fix), unten ist aber dessen History mit dran.
Änderungen neue Images:
raspberrypi.org hat geschrieben:2024-03-15:
* Audio streams will now not be interrupted when other audio devices are connected or disconnected
* Keyboard shortcut to install Orca no longer prompts for password, and will now wait for clock synchronisation rather than failing silently
* Orca screen reader updated to version 45 with various additional small bug fixes
* Obsolete fbturbo video driver removed
* Bug fix - saved display resolution settings not reloading under X
* Raspberry Pi firmware 6e0ae774407d68659b50cfbeb9f493ed16718866
* Linux kernel 6.6.20 - 6f16847710cc0502450788b9f12f0a14d3429668
2024-03-12:
* Added setting of headless resolution to Screen Configuration
* Removed setting of headless resolution for Wayland from Raspberry Pi Configuration
* Improved handling of power button on Raspberry Pi 5
* Popover windows from taskbar replaced with conventional windows
* Shutdown assistant now closes all user processes when logging out
* Wayvnc updated to improve compatibility with various VNC clients
* Wayvnc now controlled by systemd
* Audio icon on taskbar hidden if no audio devices connected
* Alternative mouse cursor shown during drag-and-drop operations
* raspi-config now allows EEPROM to be upgraded
* Speed improvement when opening bluetooth and network menus
* Tweaks to display of some widgets under dark theme
* Improved compatibility with alternative window managers
* Bug fix - prevent multiple file manager confirm dialogs being overlaid
* Bug fix - drag-and-drop in file manager causing incorrect files to move
* Bug fix - memory leaks in volume and bluetooth menus
* Bug fix - GPU load sometimes not correctly reported in plugin and task manager
* Bug fix - crash when closing windows with non-GTK headerbars
* Bug fix - spurious button hover highlights on touchscreens
* Bug fix - windows on other monitors being hidden from taskbar
* Bug fix - corrected power monitoring brownout detection
* Bug fix - wayfire keyboard layout settings sometimes not loading
* Removed fbturbo xorg video driver as it is no longer useful
* Chromium updated to 122.0.6261.89
* Firefox updated to 123.0
2023-12-11:
* Fix Raspberry Pi Imager's WLAN configuration for lite images
